cutting problems?
Ok, so I completed my build and everything seems fine with movement. I can move everything with repetier and it responds as it should. So I take a simple dxf into estlcam and get ready to cut. I move my router (using computer control) to my origin point(see photo), lower left corner of my material. When I tell it to cut either via sd card or repetier it takes off in the wrong direction (left in X and “down” in Y) and goes significantly farther that it should and drops down and starts cutting the spoil board. I’m not sure what to do at this point, hopefully I am just missing something completely stupid. I purchased everything from V1, and set up estlcam and repetier per the website instructions. I have included photos of my build below.
Once it is were you want it to begin reset the control board, or use G92 X0 Y0 Z0 (reset current position to all zeros) in your beginning GCode.
That was it, thanks. Let the making begin!
