Using Ramps 1.4 and Dual Endstop firmware
I would like to get the #define USE_CONTROLLER_FAN function working to drive a fan when the steppers are enabled to cool the drivers.
My aim is to connect the fan to D9 connection as this is controlled by MOSFET and I wont need a breakout board as I would if using an aux pin.
This would lead me to make the following declaration in config file:
#define CONTROLLER_FAN_PIN 9
However, this as this is pin is defined as “FAN_PIN” the compiler fails as the sanity check calls out the conflict.
Has anybody else successfully implemented the Controller Fan functionality without additional breakout boards?
