Wanted to add a cool pattern to a cabinet door that will sit on a cabinet hiding our internet router and fuse box. Unfortunately I made my MPCNC to small for this project so I had to settle for a design that did not cover the entire door.
Used a carbide V-groove bit at 4 mm DOC in MDF that will make up the door.
You can use positioning pins, or a stop block and work from all sides depending on accuracy needed. Those would be the most relevant for this type of thing, I think.
Pins are pretty straight forward. I think David made a 9’ ruler or something like that with 3-4 repositions.
