@vicious1,
Can I get the designed screw hole spacing for the belt block and the distance from the top of the part to the center of the hole?
I intend to mount to hss tubing that has radiused corners and I figure it’ll be more accurate if I lay out the holes pattern before hand then trying to reference off rounded edges with the part in place.
