I believe it’s fittet similar than the Titan Aero, no I was looking for that specialized bracket for the Titan, but after looking at some of the other builds, I believie it’s fitted the same way as the MK8 with the bracket
I’m just wondering if it a strong enough fit, especially with one of those Pancake-steppers
The BMG has a 1:3 ratio so those should do fine, I might eventually go for a 22mm or 25mm one.
Any thoughts about, I might missing a step or two here.
Yep might be better to go at least for a 22mm, I measured that’s about the lowest limit, eventually even the next bigger one.
Do you guys just clamp the stepper as it is, or but something in between like a rubber to make it more secure. I guess a additional heat sink at the end of the stepper could never hurt.
Update: I’m just printing your version of the bracket, couldn’t see the bottom plate on the Thingiverse picture until I loaded it into the slicer, that’s exact the thing I was looking for. Thanks.
Great, for the heat, how about putting some layer of aluminium foil in between and let it sticks out a little. Looks like s… but I’m more for practical solutions rather to win a design award.
Was looking at the Triangllab clone for the BMG clone, they seem to have great products for clones, however the extruder would go over the 22€ limit in Europe, so I went for another cheaper one.
The motor is made of metal, so some foil probably wouldn’t be much help. I had my motor current a bit too high, and with a 3:1, you do not need it very high.
