I am making some lacing things like this https://goo.gl/photos/gb6i2ZJzBazkmSSj7
They require drilling / milling a lot of holes. I was making the holes 1/8" the same size as the end mill which is ok but I think it would be better if they were a little bigger. So what is the better thing to do get a 3/16" bit or instead of drilling them mill them out with the 1/8" end mill?
The other complication is I am using a dremel for the spindle which only will take up to 1/8" so can I even get a 1/8" shank 3/16" end mill?
