Hi all. So I have my MPCNC all wired up and end stops in place. When I click on auto-home the x and y axis home but the z axis just keeps lifting until it basically comes off its guides! the Z axis doesn’t have an end stop so should it be homing?
What is the expected result when you click Auto Home on the LCD? Also I see that the menu item Prepare disappears from the menu once you click on Auto Home, is that by design?
Yeah, the expected result for auto home is just what you saw. The Z keeps on going since it has no stop. Home each axis manually or set a macro that just does the two.
By the way ensure that your z moves properly. Home z should move it down. Also check moving directions of z. If it wrong - turn 180 z stepper connector on the board
I have the same situation! the Z doesn’t stop on Home Z, while Home X and Home Y do.
So when Z is moving to make Home… it should move upward or downward? My logic says it should be moving up which is the case now, and it doesn’t stop.
Thank you Jeff for your help. I reversed the movement of the motors. I didn’t install yet a touch plate.
But I have 2 questions if you don’t mind:
1- when I home Y, only the Y0 works, the Y1 keeps moving even it touches the endstop. Shall I separate the 2 motors (right now they are connected with one single connection to the motherboard.
2- Why when I unplag the MPCNC the z0 drops?
So I have Low Rider 2. 1X motor. 2 Y motors and 2 Z motors. In total I should have 2 duals stops Y axis and Z axis. I see in Rambo (pic above ) 5 drivers… Can we configure them? Not only the EXTRUDERS=0
Is there a link where someone did this?
That picture is a mini rambo with 4 drivers, not a rambo with 5. The two Z plugs are just wired in parallel and the second Z port should never be used.
Thanks Jeff… yeah… Mini Rambo… ok! Understood. I guess I will try to have the Y with dual stops for now. But I guess at a later stage maybe I should upgrade the motherboard to 5 drivers.
For the record, you will not get more cutting performance with separate drivers. The motivation for dual drivers is dual endstops and auto squaring. I don’t have endstops on my machine. I just have hard stops to start the gantry and then the steppers move in lockstep. I wouldn’t bother upgrading unless you just want something new.
