I updated to dual endstops, and everything works great, except my rapids (G0) commands are super slow now. I verified that the gcode is correct. Is there a firmware limit I need to set/update somewhere?
VCarve. This used to work on the old firmware (or seemed to anyways). I updated the postprocessor to break those commands up to multiple lines to see if that will fix it.
I’ll give that a try. I wasn’t sure by reading the thread. Do you know if the arcs version of the postprocessor worked? It might be nice to host the file in the git repo. There are a lot of versions floating around, and I have taken bits and pieces from older ones to get mine working.
