I’m noticing all of my endstops are by default “triggered” whether I press each limit switch or not. I’m wondering if there’s something I can modify in the firmware, or if something is wrong with my Rambo, or repetier. Any feedback would be appreciated.
That shouldn’t be the behavior of the endstops in the default firmware. On the board it should be between the (s) and (-) pins. Unless you’ve got special endstops, you shouldn’t use the (+). On the endstop, it should be on the C (common, middle) and the NC (normally closed).
Just as an FYI, when I first checked the endstops without the proper software, they showed triggered. After installing the proper Rambo software, they show open even though they are wired normally closed. Ryan must have taken care of this in the code.
I do have one issue. My area is about 14” x 14”. If the spindle is far from the home point, the software seems to time out before it finds the endstops. Is there a time or distance number I need to update?
Bed dimensions are in the firmware, I think the default is 200mm square. I think if you search for soft stops you can find it, or Ryan or Jeff will chime in later and say where it is.
