Looks good to me, I use RAMPs as well (but added a Z probe) - remember to apply small steps (1mm) to test proper stepper direction (if you already attached the belts).
Finalized assembly…Apart of noise, the steppers are going nowhere…
My setup : dual end stop, mega2560-ramps-drv8825-1/32steps-LCD screen
I doubled checked my wiring, when trying to move using 1mm steps from the controller, steppers just make noise but don’t move at all…
Now, i have doubt about the wiring to the board…
Motor wire pairs are Blue/Green & Red/Black I connected there on ramps as 2A/2B & 1A/1B
Can’t see any other problems, as I followed all steps by the books?
Any ideas?
Can we get a picture of the ramps as you have it wired right now? Also, try hitting the home x button in repetier first. The steppers won’t move backwards until you home it. You can home x and y, just don’t touch the home z button.
