I understand that the mini is one driver short, however, can I still use dual endstops for X and Y?
Does anyone have any info about adding the 5th driver externally?
Or should I just give up on the mini and buy a full rambo or archim? Kinda bummed I bought the mini to be honest… but Ryan lead me to believe it’s the right thing for the LR2.
I also had this idea to put micro switches to all max positions and hook it up to the board reset - so in case there would be an accidental command past the mechanical limit it would instead reset the board. What do you think? I can’t really understand how there’s not more seriousness about disabling movement if the mechanics don’t allow it. When I had an older 3d printer that only had min endstop switches, I had it happen way too many times where the machine started forcing the steppers because it wanted to go where it shouldn’t. If possible I want to avoid that to ever happen.
