Hi all,
These are the default outputs for m119 of my MPCNC using Rambo 1.4 dual endstop firmware. Does anyone have any idea how to troubleshoot the
15:21:01.540 : Reporting endstop status
15:21:01.540 : x_min: TRIGGERED
15:21:01.540 : x2_min: open
15:21:01.540 : y_min: TRIGGERED
15:21:01.541 : y2_min: TRIGGERED
15:21:01.541 : z_min: open
15:21:01.541 : z_max: TRIGGERED
Just pressed x2_min w/ m119 and it turned to “Triggered” and isn’t turning back… wondering why I can turn them all to open by default??
jeffeb3
(Jeffeb3)
November 3, 2019, 4:17pm
2
Look at the wiring. It should be on the (s) and (-) on the board and common and NC on the switch.
I believe it’s right… correct me if I’m wrong please…
Also, is there a reliable earlier version of marlin I can use for dual endstops, jtech photonics laser, and before the current version? Rambo1.4DualEndstopLinux.
vicious1
(Ryan)
November 5, 2019, 5:42pm
4
You need to bend the wires away from the bearing, did the bearing wear through the plugs and short them?
That doesn’t appear to be the case. .
In Chas post above, he shows the M119 report as:
When I run M119, I don’t get a status on the z_maz? I’m using the Duel End stop code. Any idea why all 6 sensors wouldn’t be reported?
jamiek
(Jamie)
November 7, 2019, 7:50pm
7
Within Configuration.h in the firmware you can find a section that looks like this:
#define USE_XMIN_PLUG
#define USE_YMIN_PLUG
#define USE_ZMIN_PLUG
//#define USE_XMAX_PLUG
//#define USE_YMAX_PLUG
#define USE_ZMAX_PLUG
This will define which endstops exist and are reported by M119
