Before I jump in and order the Bundle, hoping to get some clarification:
- What is the Rambo Dual Firmware option for?
- Seems Dual endstops is to be avoided or not required, but why is that?
Thanks! Bill
Thanks! Bill
I’m assuming you’re referring to the purchase option pull down from Ryan’s shop so that means you’ll be buying the kit with a Rambo that is already flashed for Dual Endstop operation, and all the wiring harnesses required for 5 separate motor drivers and endstop switches.
I think Ryan actually mentions “why” buried somewhere in the build pages - Dual Endstop operation adds more complexity to the build, which is already a “complex” system. You have to remember folks that are building his machines have a wide varying range of technical knowledge and different degrees of reading comprehension and dispositions.
IMO - the primary benefit of Dual Endstops is self-squaring and repeatable positioning, which isn’t needed if you’re just engraving wooden signs or drawing pictures.
Erwin, yes exactly what I was referring to - thank you for the clarifications!
