I implemented my end stops this weekend and followed @thedevilsjester advice and mounted the switches on the outside. I ended up using rail mounted stop block as the trigger. I think it was this one https://www.thingiverse.com/thing:3822377
I like those end stops better than the ones I linked!
I received my replacement switches last night only to find the contact pins were very small so there is not enough material to bend. I"ll have to mount the last broken one on the outside. I do like the rail mount better than the belt mount. Even with the minimal tinkering I’ve done, I saw how belt adjustments become difficult with a belt mounted stop.
The mount that @cwford linked (well the elongated remix, of course) is 100x better than the one I linked. I switched out the ones I was using for that model and its much more accurate and stable. It was a little rough slipping them over the tubing, but you will be more happy with those than the ones attached to the belt.
