I’m just about done ordering the parts I need to build a LR2 but am wondering about its brain… I’ve been eyeing up the Duet2 wifi card for a while now for a CoreXY printer build (Voron2.1) and wondered if I should try the Duet wifi for the lowrider as well.
Have any of you used the Duet controller? I tried the forum search but couldn’t find any specific information on the installation or configuration of it for the LR2.
Did you end up going with the Duet2 and if you did, what did your config file look like? I have a spare duet wifi board and am thinking of swapping out my rambo for it. I like the Duet boards on the six 3D printers I run them on.
Wow this was a long time ago. Looking back its funny to see how ones plans change.
I never built the Voron in the end, I decided instead to build my BLV Cube printer which has been pretty solid. That does have the duet 2 wifi and I’m very pleased with it.
I printed all the lowrider v2 parts and assembled it but changed my mind based on the fact that I have no interior workshop space in the rented villa I’m in. I live in the UAE where summers get damned hot (up to 50C!) and I just have an open fronted car port to work in. I realised that I would soon get alot of complaints from the neighbours if i worked on large 8x4 projects so elected to try the burly for its smaller footprint which I will try and run with an air conditioned enclosure and hopefully use that to cut plates for a larger stronger cnc machine in the future.
