Dw 660 end Mills / bits for milling wood and ceramic tiles
What type of end Mills do you recommend to be used with the dw660.
I plan to cut / mill wood
I would also like to try engraving ceramic tile.
There are tons to use, it depends on thickness and kinds of wood. It a good idea to read up on the different style bits they make a huge difference. Check out drillman1 on ebay and his 1/8" bits. There is one for wood, and one for thin ply or sheet material that you should get.
