DW660 air blower
I’ve seen people attach air hoses to the end of the spindles to help blow dust out of cuts…
While working on a project today, I noticed that some of the exhaust holes on the DW660 push a lot of air. Has anyone thought of 3d printing a shroud for the exhaust ports to redirect that air down towards the workpiece?
I think I’ll start on a design for that once this project is done.
I did exactly that. I didn’t mention it but Marion noticed and asked about it.
I put it up on thingiverse as-is. It doesn’t have a good print orientation and needs supports. DW660 blower redirection by Jamie_K - Thingiverse
The two little pegs go into the ‘nostrils’ and the upper holes are for adjustment screws to tweak the angle (#6 sheet metal screws with the ends made blunt).
I’ll warn you, this blower makes a big mess.
That might work. I need it to clear the button hole for the bit removal.
My first time trying to do a 3d contour… My ability to see space on the screen was pretty bad.
