Hi,
I’m trying to make some gears with ma MPCNC. But I can’t make a correct dxf to do that.
Look at the pictures, I often have this problem each time I try to have some ‘curves’ in my sketch. I don’t know if the problem comes from Onshape or Estlcam.
In Onshape, I tried all types of DXF (Release 14, 13, 12, 2000, 2004, etc…).
If I import back the exported DXF in Onshape, I’ve no error.
If I import the same DXF in Freecad, I’ve got something even stranger.
Has someone an idea about the problem I have? Is it Onshape or Estlcam which is the problem?
I searched several hours on internet to find an answer, but it doesn’t seem to be a famous problem.
Any idea is welcome, because I 'm stuck in the early beginning of a project…
