E3D v6 Bowden Hotend (16mm Groove Mount) and Makita RT0700CX Router
Mounts for both are here: http://www.thingiverse.com/thing:1008647
I’m using an international version of the CNC, though should work with both I think? Happy to share design files if anyone wants them, not sure what format to use though? Designed them in Fusion 360.
E3D mount should work with any 16mm ‘groove mount’ hotend.
Thanks for that! They will only fit the international though. Unfortunately the two are a bit different. If you do want to share the files my best guess would be saving them as a parasolid, most programs can handle those.
