East Temple Peak, Wyoming Topographic Map
5mm birch plywood. 200mm x 200mm x ~60mm
A friend asked if I could help out with a gift. Initially he wanted to hand cut out vinyl using a printed topo map of the area. I asked if I could do it in wood and use a machine. He said yes.
Initially I tried using a geographic data to STL tool (http://jthatch.com/Terrain2STL/) with Fusion 360 Slicer. This would have been ok, but at the scale / resolution I was going for it just looked like blobs with little definition.
After a couple hours looking for high-resolution data sets, I caved and manually mapped a jpg map to vector in Illustrator. It took a little bit, but gave me the resolution I was looking for.
Some of the smaller bits for the top layer turned out to be too small. I am still trying to get my head around a ‘minimum’ shape for this machine.
Please come back with pics of the finished project. Neat stuff!
That’s really neat. I like the registration pegs.
I guess this would rely much on the size of mills you use? I recently ordered a few 1 and 0.8mm mills. I’m very curious to see how they perform, I honestly expect them to break just when installing them…
Set the feed very VERY low! Way lower than you think to start.
In fact, you might want to actually do some calculations. :slight_smile:
I use 1mm mills at 500 to 600 mm/min with no problems at 1.5 to 2 mm doc . I cut mostly cherry I’m sure they will work well for you
Thanks everyone for the compliments and the suggestions!
I am also thinking not cutting all the way through on the smaller parts, just scoring the top surface, then cutting them out by hand / cleaning up after. I was using tabs, but they were not much help at that small scale.
