Good choice, that should work well. I think it would be an awesome idea to make sure you can hang material out of either open end in case you do bigger things. like a sliding or removable door at each end. I tend to mostly do material that hangs off the table.
That is the plan, there will be a removable back plate and I’ll just leave the cover open if needed to stick out the front. The cut area is around 22" x 16" with the longer side oriented for allowing cut tiling.
I did some cuts for a friend and he bought a really nice piece of wood and wanted the same thing cut along it at 1’ spacing. So I just slid it through 1’ at a time, front to back. I guess it all depends on your end use, Just a thought.
Added a spoil board, I bought this router bit from ebay and routed a t-track channel every 3" in 3/4" sanded plywood. It is nailed down to the printer bed with a few small nails which I’ll pry off when it needs changing eventually.
I wanted t-track but real t-track was cost prohibitive, this works well and was quite cheap.
