Sometime when I use kiri:moto once the job is finished it will for whatever reason on its way back to origin cut through the entire work piece. It only happens on occasion but it’s quite annoying to say the least. Would any gcode fluent tinkerers be able to look at the last lines of gcode to see if theres some command I can remove to prevent this?
clock-tabs.gcode (68.2 KB)
