I purchased everything from here.
I found out using a multimeter that the board likes NO (I think I saw in the firmware that the logic was inverted" Makes no difference since it just has to cut the circuit.
For X and Y (didn’t test Z yet) end stops, the MIN works just as expected. The minute I press down on the endstop (wired as NO) the motors stop. But for X or Y MAX, it doesn’t work. Just to test, I wired the MAX as NC and still nothing.
You can see from this picture what I’m talking about. I wired the top pin as Signal and the middle pin as GND. I ruled out the stoppers or cabling because if I take a known-good XMin setup and plug it into X or Y MAX pin, it doesn’t work. Conversely, if I take the endstop/wires from the X or Y MAX (which doesn’t work) and plug it into M or Y MIN, it works just fine.
What am I doing wrong?
TY
