TheFreddyD
(Fred Dirosato)
August 15, 2020, 2:35pm
1
I have made I believe all the configuration changes and the M119 command returns this with all 5 end stop triggered.
10:02:53.995 : N14 M119*31
10:02:54.001 : Reporting endstop status
10:02:54.001 : x_min: TRIGGERED
10:02:54.001 : x_max: TRIGGERED
10:02:54.001 : y_min: TRIGGERED
10:02:54.001 : y2_min: TRIGGERED
10:02:54.001 : z_min: open
10:02:54.001 : z_max: TRIGGERED
10:02:54.001 : ok
This is with all switches open
10:04:05.470 : N40 M119*30
10:04:05.474 : Reporting endstop status
10:04:05.474 : x_min: open
10:04:05.474 : x_max: TRIGGERED
10:04:05.478 : y_min: open
10:04:05.478 : y2_min: open
10:04:05.478 : z_min: TRIGGERED
10:04:05.478 : z_max: open
10:04:05.478 : ok
I only use one X so that explains no change on x_max
It seems the z_min works in reverse of what it should. I replaced the switch, ohmed out the wire and same results
I check the board connections and they are correct.
Here are my configs.
FreddyD Config 081520.zip (72.1 KB)
All help is appreciated! this is the last thing before i get this baby going.
jeffeb3
(Jeffeb3)
August 15, 2020, 3:40pm
2
The zmin is inverted to use a probe.
Which firmware are you using? Was it already configured for the low rider?
robertbu
(Robert Bunney)
August 15, 2020, 3:46pm
3
I donāt know anything about the Lowrider in particular, but if on the Primo, the x_max being TRIGGERED in both states indicates a break/problem in the wire.
TheFreddyD
(Fred Dirosato)
August 15, 2020, 4:40pm
4
I had to had load and mod my it, board came unloaded from V1. All good just working out the kinks.
My Version is 427D 2.0.5.3
TheFreddyD
(Fred Dirosato)
August 15, 2020, 9:19pm
5
Okay what did I do? I killed the config on my Rambo 1.4 and now when I try to do a build in PlatformIO I get this?
Verbose mode can be enabled via -v, --verbose
option
CONFIGURATION: Redirecting...
PLATFORM: Atmel AVR 2.2.0 > RepRap RAMBo
HARDWARE: ATMEGA2560 16MHz, 8KB RAM, 252KB Flash
DEBUG: Current (simavr) On-board (simavr)
PACKAGES:
framework-arduino-avr 5.0.0
toolchain-atmelavr 1.50400.190710 (5.4.0)
LDF: Library Dependency Finder ā http://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 15 compatible libraries
Scanning dependenciesā¦
Dependency Graph
|-- 1.5.0
|-- 0.7.1
|-- 1.1.0
|-- 1.5.0
|-- 0.4.1
|-- 0.8.0
|-- 1.0.0
|-- 1.2.7
Error: Nothing to build. Please put your source code files to āC:\Router\Marlin-1CNC_Rambo_Dual_2\Marlin-1CNC_Rambo_Dual\Marlin\Marlinā folder
======================================================== [FAILED] Took 1.42 seconds ========================================================
Environment Status Duration
mega2560 IGNORED
mega1280 IGNORED
MightyBoard1280 IGNORED
MightyBoard2560 IGNORED
rambo FAILED 00:00:01.423
FYSETC_F6_13 IGNORED
FYSETC_F6_14 IGNORED
sanguino644p IGNORED
sanguino1284p IGNORED
melzi IGNORED
melzi_optiboot IGNORED
melzi_optimized IGNORED
at90usb1286_cdc IGNORED
at90usb1286_dfu IGNORED
DUE IGNORED
DUE_USB IGNORED
DUE_debug IGNORED
DUE_archim IGNORED
DUE_archim_debug IGNORED
SAMD51_grandcentral_m4 IGNORED
LPC1768 IGNORED
LPC1769 IGNORED
STM32F103RC IGNORED
STM32F103RC_meeb IGNORED
STM32F103RC_fysetc IGNORED
STM32F103RC_btt IGNORED
STM32F103RC_btt_USB IGNORED
STM32F103RC_btt_512K IGNORED
STM32F103RC_btt_512K_USB IGNORED
STM32F103RE IGNORED
STM32F103RE_btt IGNORED
STM32F103RE_btt_USB IGNORED
STM32F4 IGNORED
STM32F7 IGNORED
ARMED IGNORED
STM32F103VE_GTM32 IGNORED
STM32F103VE_longer IGNORED
mks_robin_mini IGNORED
mks_robin_nano IGNORED
mks_robin IGNORED
mks_robin_pro IGNORED
mks_robin_e3 IGNORED
mks_robin_lite IGNORED
mks_robin_lite3 IGNORED
jgaurora_a5s_a1 IGNORED
STM32F103CB_malyan IGNORED
mks_robin_nano35 IGNORED
STM32F070RB_malyan IGNORED
malyan_M300 IGNORED
chitu_f103 IGNORED
chitu_v5_gpio_init IGNORED
STM32F103RET6_creality IGNORED
STM32F401VE_STEVAL IGNORED
FLYF407ZG IGNORED
FYSETC_S6 IGNORED
STM32F407VE_black IGNORED
BIGTREE_SKR_PRO IGNORED
BIGTREE_GTR_V1_0 IGNORED
BIGTREE_BTT002 IGNORED
rumba32 IGNORED
esp32 IGNORED
teensy31 IGNORED
teensy35 IGNORED
linux_native IGNORED
include_tree IGNORED
=================================================== 1 failed, 0 succeeded in 00:00:01.423 ===================================================
The terminal process āC:\Users\fdiro.platformio\penv\Scripts\platformio.exe ārunāā terminated with exit code: 1.
Any thought I was getting close then I Killed It !
