I purchased the lowrider kit about 6 months ago. I am endeavoring to add on end stops now. My kit came with 4 end stops and wires. What else will I need for this project? Will I need to flash different software onto the board or is the board already set up for it?
We need more information.
What wires did you buy with the kit, what firmware does the screen say when you boot, what board and screen do you have?
2.0.7.2 v1cnc 5108
Serial wire
Rambo 1.4
Endstops are only really worth it if you wire your steppers individually, and yes you would need new firmware.
I figured that. I ordered the individual wiring kit along with more end stops and the harnesses you sell. I take it that should do it?
Yup. That should do it after you flash your board.
Thanks as always Ryan.
