Resend: -65424
Error:Line Number is not Last Line Number+1, Last Line: -65425
[ERROR] Error:Line Number is not Last Line Number+1, Last Line: -65425
I’m following the Estl-Basics instructions but I keep having this issue.
When I try to run the gcode with repetier or pronterface I get the above error. I tried printing from the display but the board resets when it hits this part.
I received my board from Vicious1. I reflashed it according to the instructions with his marlin firmware.
This starts immediately when I begin the print.
Beginning of my GCODE:
;Project 0059
;Created by Estlcam version 9 build 9.018
;Machining time about 00:00:35 hours
If you are using the RC8 firmware you need to update ESTLcam to the one he put out this morning. Have a look through the basics page as I just updated some settings.
Sorry for the confusion but things are about to get a lot easy and more reliable starting this morning!!!
I tried again running the file through Estlcam. I loaded the gcode into Repetier-Host and started the print. It moved to the start and crashed with errors.
Error:No Line Number with checksum, Last Line:12
Error:Line Number is not Last Line Number+1, Last Line:12
Resend: 13
I reloaded the file in Repetier-host and hit print again. It printed this time no errors and returned the pen to the starting place. Perfect!
I’m still confused as to why it doesn’t work the first time.
Awww…I just noticed I have “Killed. Printed Halted Please reset on the display”
