Hello, I was doing some tests for my work table size and Gantry extremes position and realize when I set the command of: “G00 X470.0000 Y380.000 Z5.0000 F2100” that is the extremities of my worksite bed the Gantry is sent to the opposite side of Home, that is correct. So when I press HomeX button in Repetier host Mac, the gantry moves to half way of X and stops, I found the last line shows in red: “ERROR: Print halted. kill() called!”, and I have to disconnect and connect again to get the Gantry to move. Is there some related to the bed size or machine size? Do I have to set bed size in the firmware? I did not.
I am using endstops, LCD, Repetier, on the Mac.
[attachment file=119738]
[attachment file=119739]
[attachment file=119740]
