Tried to do a test print today but keep getting the following error. I don’t have a heated bed as i thought for pla you don’t need it. do I need to adjust something in the firmware and re flash it?
Check the connection on your thermistor. It’s either not plugged in, not mounted properly on the printer or faulty. MINTEMP means that the board is not registering any temperature
