I have a bunch of holes I want to cut to the same partial depth. It seems like I need to set each hole depth settings individually. Is there a way to do several holes at once?
Yes you can use auto create features, then just select all of the created cuts and edit them all at once. Or you can just manually create drills for each of the holes by clicking like mad, then again select them all and edit the depth, and cut criteria all at once.
