I’ve tried to use EstlCam (this is the software used to make it ?) but i have some difficult to create 2.5D model (if i have to create a simple profile ok, but what if i have to create 2.5D ?)
There are some guide for this topic ?
What is the source file to create 2.5D ? A flat image or a model like in a 3D printer ?
If you use a .STL file, like a 3D printer a whole new menu opens up. you should be able to get it from there. There are a few things you can do to optimize the speed but a little googling and you should be able to get a decent part out without it.
I will make a 2.5/3D walk through in a week or two.
Hi,
i’ve done as you suggest and look some videos.
I’ve setup EstlCam as “Z-Axis origin: Material Upperside”, that because my stock is 10mm taller and my model is 7mm (so i want to start cutting from top to bottom).
The problem now is with RepetierHost, because when i press “Print” Repetier first go at home (and Z Axis have home on bed).
What modification i have to do in Repetier to say “When i press print, start cut from where you are?”
I’ve also tried to setup EstlCam as “Machine Bed” but in this way first it cut the bottom of the piece and later go up (this is wrong because in this way Dremel cut too much material each step).
Did you solved this problem ? I’m trying all configuration but every time it go first home and later start to cut (and sure, the drill is on the bed and not in top of surface!)
I’ve finally resolved!!! I was enabled min_software_endstop on my Marlin, after disable it (and sure, i move my machine in the correct position and reset home) all go fine!!!
I’ve tried to cut my first part and the result is… very bad
You should not have had to change anything in marlin if you are using mine.
Yes, rough and finishing in the same gcode. You rough down to a minimal amount of material with a 45% stepover and then finalize with a 1%-10% stepover depending on desired finish.
Unfortunally i cant use it because i have 8mm 1,25 threaded rood but i have A4988 driver (with max 16th steps) and T2.5 timing belt with 16th Tooth Pulleys
Looking in your configurations (here on site), i dont find one with this characteristics.
However, now all go fine :)))
I will wait for some tutorial on how to use EstlCam with .stl and have a better result then mine :)))
You should start with my beta firmware and just change the steps per mm. I think the accelerations and speeds will hold up. At 16th steps you can rapid faster but I don’t recommend it.
Francisco,
For your 8mm/1.25pitch threaded rod your firmware should have:
Z Microsteps/mm = (16Microsteps/Step)(200 Steps/Revolution)(1Revolution/1.25mm) = 2560 Microsteps/mm.
So you do have the correct value. Are you sure about your Z measurement?
With this configuration (that will need 2,5 hours to complete the work!!) the phrase Kiss is veeeeerrryyyy smooth and pratically collapsed -> not very slim like in the model…
i’m almost sure about the measure because i have a wood 10mm (1 cm ) taller (measured with caliber) and after in Repetier i press plus 10 on Z axis, this piece dont fit under the Mill.
