Hello there,
I’m starting to cut out the frame to build Ryan’s Mostly printed 3D printer. I wanted some advise on how to use Estlcam to cut it out. I went through the 2.5D tutorial and I’m thinking it would be nice to try out the allowance setting to get a cleaner/smooth finish. Does my tool now need to go through all the passes again after the initial rough passes or is there a way I can do the smooth pass a couple of times instead of 6-7? Or am I just better of sanding the frame when it’s finished? Any thoughts or suggestions would be great. Thanks!
