Hi,
The instructions for EstlCam Basics says the following:
The creator of Estlcam recently updated his software for us! In the CNC Program Generation tab, choose Marlin (if you are using my firmware).
1-Important – Set feed unit to mm/min- (this is what the marlin firmware needs).
2- Change the file extension “ gcode ” so all the programs recognize it.
3- 10/23/19 – Uncheck Arcs G02/G03
I am using the latest version of the v1engineering provided marlin firmware. I am not sure what the date “10/23/19” means. Does that mean to uncheck if the firmware is before that date?
Thanks in advance
