So while I’m printing parts I figure I start to learn Estlcam and Repitier. I know this is not the Estlcam/Repitier forum but I figured you guys have seen it all.
What is the version of Estlcam I should start with 9.047?
I dragged the .dxf crown into Estlcam, but when I try to enlarge or shrink I don’t have a dialog box that let’s me type in a specific values. I can drag to enlarge/shrink. Bug? I saved the gcode and dumped it into Repitier and ran a dummy test.
If I just want to lay text down in the work area, it seems I need to insert a dummy .dxf file first? If I click the txt button, it says no drawing is opened at the moment. If I just want to make a sign what are the steps?
Z
