Hello,
I’m running Estlcam 11.235_b_32 with an MKS DLC V2.0 with firmware 1.1. For some reason I can’t cut circles. All it does it cut lemons.
Has anyone experienced this with Estlcam? I’m importing the gcode into OpenBuilds Control.
[10:36:47] [ ] Grbl 1.1g [’$’ for help]
[10:36:48] [ $$ ] $0=10 ;Step pulse time, microseconds
[10:36:48] [ $$ ] $1=255 ;Step idle delay, milliseconds
[10:36:48] [ $$ ] $2=0 ;Step pulse invert, mask
[10:36:48] [ $$ ] $3=6 ;Step direction invert, mask
[10:36:48] [ $$ ] $4=1 ;Invert step enable pin, boolean
[10:36:48] [ $$ ] $5=0 ;Invert limit pins, boolean
[10:36:48] [ $$ ] $6=0 ;Invert probe pin, boolean
[10:36:48] [ $$ ] $10=1 ;Status report options, mask
[10:36:48] [ $$ ] $11=0.020 ;Junction deviation, millimeters
[10:36:48] [ $$ ] $12=0.002 ;Arc tolerance, millimeters
[10:36:48] [ $$ ] $13=0 ;Report in inches, boolean
[10:36:48] [ $$ ] $20=0 ;Soft limits enable, boolean
[10:36:48] [ $$ ] $21=0 ;Hard limits enable, boolean
[10:36:48] [ $$ ] $22=1 ;Homing cycle enable, boolean
[10:36:48] [ $$ ] $23=3 ;Homing direction invert, mask
[10:36:48] [ $$ ] $24=100.000 ;Homing locate feed rate, mm/min
[10:36:48] [ $$ ] $25=1000.000 ;Homing search seek rate, mm/min
[10:36:48] [ $$ ] $26=250 ;Homing switch debounce delay, milliseconds
[10:36:48] [ $$ ] $27=5.000 ;Homing switch pull-off distance, millimeters
[10:36:48] [ $$ ] $30=1000 ;Maximum spindle speed, RPM
[10:36:48] [ $$ ] $31=0 ;Minimum spindle speed, RPM
[10:36:48] [ $$ ] $32=0 ;Laser-mode enable, boolean
[10:36:48] [ $$ ] $100=47.300 ;X-axis steps per millimeter
[10:36:48] [ $$ ] $101=47.300 ;Y-axis steps per millimeter
[10:36:48] [ $$ ] $102=200.000 ;Z-axis steps per millimeter
[10:36:48] [ $$ ] $110=2500.000 ;X-axis maximum rate, mm/min
[10:36:48] [ $$ ] $111=2500.000 ;Y-axis maximum rate, mm/min
[10:36:48] [ $$ ] $112=2500.000 ;Z-axis maximum rate, mm/min
[10:36:48] [ $$ ] $120=150.000 ;X-axis acceleration, mm/sec^2
[10:36:48] [ $$ ] $121=150.000 ;Y-axis acceleration, mm/sec^2
[10:36:48] [ $$ ] $122=150.000 ;Z-axis acceleration, mm/sec^2
[10:36:48] [ $$ ] $130=1000.000 ;X-axis maximum travel, millimeters
[10:36:48] [ $$ ] $131=1000.000 ;Y-axis maximum travel, millimeters
[10:36:48] [ $$ ] $132=100.000 ;Z-axis maximum travel, millimeters
[10:36:48] [ $$ ] ok
[10:36:48] [ $I ] [VER:1.1g.20181112:CUSTOM]
[10:36:48] [ $I ] [OPT:V,15,128]
[10:36:48] [ $I ] ok
Before I started having trouble I was able to cut this:
It stopped cutting out the perimeter with an error:
Thanks,
Brandon
