Can I use a dxf to create multiple depth holes? I want to mostly just cut straight through, but I have a few tiny holes that I only want to go a specified distance into the work piece.
Whenever you select a path for hole/part/carve, you can specify the depth for just the selected item.
Also for that, if the “Holes” aren’t going all the way through, you will want to set the depth here, then choose pocket, depending if the “Hole” is larger than the tool diameter.
Thank you sir! Great explanation!
