Hi Guys,
I’m still experimenting with CNC milling and Estlcam.
I’ve realised that, all the time, when doing the first pass of a cut, the CNC seems to plunge a lot deeper than it is supposed to be.
Let’s say I want the tool to plunge 1mm deep for each layer, I then position carefully the bit right on top of the wood piece, just touching it, then launch the job in repetier. It will start by cutting the first layer almost 2 mm deep instead of just one.
This is quite a big issue, because I need to slow down the CNC each time it goes into the first layer, otherwise it may lose steps because of the huge increase of the load.
When I click on the previsualisation of the toolpath in Estlcam, I can see that even in the simulation the first pass seems to be deeper than the others.
So I guess it may be a wrong setting I did somewhere… Any thoughts?
