This is going to sound repetitive, but I can’t find my earlier post;
DXFs are not opening in Estlcam - I have exploded the layers, I have put them all in one layer, and saved it into DXF 2013 from my AutoCAD 2014 version. Something isn’t happening and I can’t recall what it is.
My file is set up in mm and I have attempted to open the DXF in both mm and inch. Ugh!
I’m missing something - I thought I had it sorted, but time clears the short term memory and I have lost it.
Splines won’t get exploded - so I took the time to redraw my shapes and do it again, but nothing. Now I am shifting CAD rograms and trying to open both dwg and dxf in FreeCAD and F360 to see if I can get it hopping - but no joy. This is getting ridiculously frustrating. I’m about to pitch the whole thing!
I have no answer, but if you put the AutoCAD .dwg file as well as the .dxf file in a ZIP file and attach it to a post in the forum, I’ll see if I can find a pathway.
Well, I don’t know what AutoCAD is doing - but I imported that DXF into FreeCAD, did all the things needed to take the shapes and make them sketches then exported all the sketches into a new DXF and voila! It’s in Estlcam to get tool paths going. I’m done for the day! I’ll be doing most of my future drawings in FreeCAD from now on I think.
I figured JeffB would like that I finally turned to FreeCAD!
I will post the files up in a bit. My hesitancy is that there is three lines/objects overlapping in a 2D file that makes the easy posting of the files a little difficult to understand up front without a load of explanation. So I’ve completed a work around and drove on. Sorry. I think I’d like to know what is holding Estlcam up from using my AutoCAD DXF, but right now production is overruling troubleshooting.
