Hi everyone,
I am trying to do my first cut out of some plywood after validating that evrything work with some pen drawings.
I am using ESTLCAM and Repetier to do the job. My MPCNC is on standard setup with all recommended hardware from Vicious, Marlin RC7 and 8mm threaded rod.
I have set up ESTLCAM like on the tutorial to comply with Marlin RC7 firmware, Marlin is set up for 1.25mm/revolution on Z axis because of my 8mm threaded rod.
I think i have everything fine BUT… i am facing a problem
After drawing it with a pen, I try to make the tutorial of the crown but with a 4mm bit and a plywood sheet.
- I tried a first one asking for 0.5mm engraving: everything went fine except i forgot to measure how deep the engraving result was after the job ended.
- Happy of that first try i started the same job asking for 3mm engraving depth and my tool was set up to make 1mm depth per pass. If i understand everything okay this should have generate 3 passes of 1mm depth.
So i hit the start button and the bit directly went to a 3mm depth into the plywood and started to draw !! It took me some seconds to realise that because it seemed to ran okay but i had to cut-off the job because the bit was stressed out (loud noise, vibrations)
I decided to take my caliper and measure the depth of the first engraving and saw a 1.15mm depth instead of the 0.5mm asked and on the second try i had a 3.8mm instead of 3mm and in just one pass when it should have done it in 3 passes…
I checked everything this moring during more than 2 hours : checking the gcode, checking estlacam parameters, checking repetier host, marlin firmware config.h and searching the forum for similar problem…
Could someone help me and point in the right direction to sort this problem out because i obviously made something wrong… but where ??? That’s a mystery to me
Thanks for all your help in davnce
