After loads and loads of research for traditional CNC routing my maker friend just tosed the lowrider at me.
Since I’m going to jump into this i have some questions.
I read that once everything is dialed in and a break in period is complete rechecking screw tesnsion.
- For those that have gone with end stops and getting everything (feed rate etc..) dialed in, how often are you re-tensioning the belts/parts and have you experienced parts breaking or stretch belts overtime?
- What is a realistic cut quality for each axis using recommended cut rates "0.003 or 0.03 ?
- Using the DWP611 have you gotten to a point where your worried the spindle will catch fire or implode?
- What would be a realistic runtime where the system should rest vs going 24/7?
- I will be cutting 0.75 cabinet melamine & plywood. Would downward spiral bits be the most ideal?
- Using the store as my parts base what is the turnaround time? I noticed most parts seem on par with the open market, would purchasing the Rambo put some additional coin in for the designer in addition to donations?
