Hey, I’ve got a(n?) LR2 and am looking at buying the $14.99 wiring kit that Ryan has listed on the site. Just wanted to check first and make sure someone else has successfully extended theirs before I do it.
I know I can plug and play these into my existing connectors, but should I be worried about any signal noise from doubling the length of my wiring or should I be good to go? I’ve got an enclosure to keep dust out of the air and would like to set up my controller outside of it.
Also, piggyback question - does anyone know if ESTLCAM has a command limit for a single job? I was engraving something big, had ~250 engravings along with 9 part cut-outs in the gcode and it randomly skipped a batch of around 12 of them at the end. I double checked my file and the engravings are in the previewer, and in the gcode, but the machine skipped them as far as I can tell and moved on to my tool change. Anyone experience something like this before?
