Hi everyone. I just finished my lowrider recently but now I believe my control bird is going bad.
I have successfully cut/drawn about 15 things but it’s periodically getting worst and the driver is failing on the x axis.
It started first with the x axis failing mid program and just shaking in spot. So it was as if I was attempting to move to the next step but wouldn’t.
It progressed to become worst and stopped shaking and just stoped moving at all. It also started to happen much earlier in the program.
My reasoning why I believe it’s the drivers:
While malfunctioning if I switch the x axis steppers to a different drive axis they function fine. And if I switch a different stepper to the output of the x axis they fail. So that has pointed me to the board and not wiring.
it will work fine again after a power cycle.
I checked all conductance in the wiring and they are perfect.
So long story short trying to get some feedback if anything else I should try before I can get this replaced from v1
