What would cause this? I’m printing 1mm deep with a total depth of 1mm using a .125" (.3mm) endmill. The cut in either linear or parallel at 1mm is flat, but then the bit raises and lowers for the outline (at the end of the gcode), and cuts a hair deeper.
Z
