Hey all,
I’ve been using my Lowrider 2 (Rambo Mini, Pi 3B+) sucessfully for a couple of years now, I also have a Maslow that I built a couple of years before that.
I’m using CNC.js on V1PI 1.19.23 that I just installed. This is my first project with 1.19.23. 1.19.22 would randomly lock up on me while cutting or lasering, I haven’t got that yet with the newer version. Finger crossed.
Anyway, I’m making a retirement plaque out of walnut (pictured is a pine test piece) that I designed in Vectric Aspire 11.014. The roughing pass (3/4 inch core box bit) went fine and the finish pass (1/4 inch ball nose bit) started out fine and about 10 minutes in started cutting random straight grooves for no reason. I witnessed the first errant cut: It was cutting from center out with a 10% stepover climb cut when about 10 minutes in the router stopped and backed up about 7 inches to the edge before continuing the G-Code as it was supposed to. It did this 5 or 6 more times in different spots before I stopped it.
There isn’t anything wrong with the G-Code, it simulates fine in Aspire, NC Corrector, and CNC.js. I have also run the finish pass on my Lowrider two (2) other times without issue.
See attached photo, unwanted grooves highlighted in black. So, is there a ghost in the machine somewhere? Is there a temporary folder on the V1PI microSD card that needs cleaned out? Sun Spots?
Thank you,
Paul
