ok Friend, I’m going to gather the information and make the process now it’s clearer thanks a lot for the help I’m going to acquire material for Up Bootloader
this is the message I gave when I tried to upload without Bootloader Prusa.
Ari via slicer.
avrdude-slic3r -v -p atmega2560 -c wiring -P COM3 -b 115200 -D -U flash:w:0:C:\Users\Samuel Conegunes\Downloads\prusa3d_fw_3_10_0_MK25S\prusa3d_fw_MK25S_3_10_0_4481_RAMBo13a_en-cz.hex:i
avrdude-slic3r: Version 6.3-20160220-prusa3d, compiled on Jul 16 2021 at 12:28:18
Copyright (c) 2000-2005 Brian Dean,
Copyright (c) 2007-2014 Joerg Wunsch
Using Port : COM3
Using Programmer : wiring
Overriding Baud Rate : 115200
avrdude-slic3r: stk500v2_getsync(): got response from unknown programmer , assuming STK500
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Wiring
Description : Wiring
Programmer Model: STK500
avrdude-slic3r: stk500v2_command(): warning: unknown, code 0x90
avrdude-slic3r: stk500v2_getparm(): failed to get parameter 0x90
avrdude-slic3r: stk500v2_command(): warning: unknown, code 0x91
avrdude-slic3r: stk500v2_getparm(): failed to get parameter 0x91
avrdude-slic3r: stk500v2_command(): warning: unknown, code 0x92
avrdude-slic3r: stk500v2_getparm(): failed to get parameter 0x92
Hardware Version: 0
Firmware Version Master : 0.00
avrdude-slic3r: stk500v2_command(): warning: unknown, code 0x9a
avrdude-slic3r: stk500v2_getparm(): failed to get parameter 0x9a
Topcard : Unknown
avrdude-slic3r: stk500v2_command(): warning: unknown, code 0x94
avrdude-slic3r: stk500v2_getparm(): failed to get parameter 0x94
Vtarget : 0.0 V
avrdude-slic3r: stk500v2_command(): warning: unknown, code 0x98
avrdude-slic3r: stk500v2_getparm(): failed to get parameter 0x98
avrdude-slic3r: stk500v2_command(): warning: unknown, code 0x95
avrdude-slic3r: stk500v2_getparm(): failed to get parameter 0x95
avrdude-slic3r: stk500v2_command(): warning: unknown, code 0x96
avrdude-slic3r: stk500v2_getparm(): failed to get parameter 0x96
avrdude-slic3r: stk500v2_command(): warning: unknown, code 0x97
parameter 0x97
SCK period : 0.5 us
Varef : 0.0 V
Oscillator : Off
avrdude-slic3r: stk500v2_command(): warning: unknown, code 0x9e
avrdude-slic3r: stk500v2_setparm(): failed to set parameter 0x9e
avrdude-slic3r: stk500v2_command(): unknown status 0xc8
avrdude-slic3r: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude-slic3r: stk500v2_command(): unknown status 0x01
avrdude-slic3r: stk500v2_disable(): failed to leave programming mode
avrdude-slic3r done. Thank you.
