The problem…
I had literally just finished resurfacing the entire spoilboard on my Lowrider2 when I looked down and saw this — oh nooooo!
Apparently, a screw (or screws) came loose and the PLA finally gave out. But even worse, this means my freshly resurfaced spoilboard is not level…@#$%!
The solution…
I was fully intending to print a new set of original parts when I happened to stumble across this creation on Thingiverse.
It was at this point that I knew what I had to do. So here we are, some 2 weeks later, with my very first aluminum parts made from 2"x2"x0.25" aluminum square tube (6061). I had to make a few small tweaks to the DXFs, and I had to switch from VCarve to Estlcam to take advantage of trochoidal milling (after breaking one 1/8" bit and clogging another attempting to slot cut). I ultimately used an Amana Tool 1/4" Spiral ‘O’ Flute, which did an excellent job once I figured out the proper settings.
I think they turned out pretty well…
Back in action…
Now, the Lowrider2 is officially back in action! Except for needing to resurface again… So far, the machine feels extra sturdy and I’m completely digging the upgrade.
Memories…
Although this is my 3rd time rebuilding the machine, I had to keep my original blue vinyl V1 cord cover. It was one of the very first things I made when I started this journey, and it’s a nice reminder of how far things have come.
