I made my first cuts and engravings in alumnium with my Lowrider2. Thanks to all the recommended settings and router bit tips, they tourned out pretty well
4mm sheet with 400mm/min and 1mm DOC went very well. A little bit chatter, but I found out that some roller bearings on the Z rollers were a liitle loose… will have to fix that
I made a fanshroud for my Lotus Exige Sports Car which always had to fight with heat in the engine bay. The additional fan should solve that problem
I really like seeing this. I’m working on a kit car, and there is a ton of stuff I can do once I get past the wiring. I can’t wait until I’m at a point where I can start milling flat parts to do stuff and look cool!
Please keep posting these!
