I still have a lot to learn on the engraving part of the machine.
This was done with a 1/8" 45* End Mill.
I spray painted the pine black to make it easier to see what it was doing. It looks like I missed the middle parts of the letters. I created the text with Adobe Illustrator and used F-Engrave’s bmp import option.
Dude, If you did custom broom sticks at a craft fair you would be rich. The ultimate gag gift, I think I will send one to my older sister…Trust me, I owe her.
What I learned after some more reading is that F-Engrave works well for lettering and outlines, but I need to find something else if I want to engrave greyscale bitmaps.
I don’t have illustrator. But EstlCAM can read SVGs. I thought illustrator was similar to inkscape (vector graphics). I have used inkscape to make letters, saved as SVG and loaded into EstlCAM for carving.
I will say, if you’re using EstlCAM, a recentish update made carving a lot better. Especially if you want to hog out the middle with a flat bit. IIRC, I moved from 10.09 to 10.39 or something, and that stuff got way better.
It’s free to use. It will just have a box that stops you for a wait whenever you save gcode. The wait time increases. I used it for like 6 months before I bought it. I ended up buying it just because I had used it so much, and felt guilty. The timer wasn’t enough to stop me, but it was a good reminder that I wasn’t doing anything to help.
I can’t get estlcam to do an engraving that includes all the dark parts of a B&W logo/text. It seems to only want to do the outline.
I got F-engrave to do the full text including the filled parts of the letters, but then I had the feeds set all wrong and burned up my 45* end mill. I didn’t realize it tries to plunge to the full depth and doesn’t do a step-down path. It bored down into the wood and started smoking.
In EstlCAM if you want to do more that a line you should use carve, it allows for sharp corners and open spaces. I think if engrave as in I am attaching an engraver and it is just going to follow a line, that is how I use the drag knife and laser. Most anything else will be carve.
You should have a quick look through my videos or some old guy coding, or Christian from estlcam. We don’t have to many videos but I believe we have easily covered everything you might ever want to do with your machine.
Also check the option for a pocketing tool or something like that. Making the pocket with the v bit will wear it a lot, and will take hours when a straight bit will do it much faster.
