[attachment file=99964]
Stencils cut on MPCNC, Cheap 1/8" single carbide bits. 10 for $10 eBay. Aluminum trim coil.
1" x 12" pine board. Measures 11 1/4" x 18 3/4". Paint first, then carve.
Burnt edges with propane torch and clear acrylic top coat.
Carving done with 45∘ bit from V1.
I should include a picture of all the scrap I’ve made in the process.
[attachment file=99960]
[attachment file=99961]
[attachment file=99962]
Nice, that is how you use a CNC!
Tool change success.Amazing detail for size.
Carve 50mm x 77mm, White Oak Wood
Tool 1) 1/8 single flute, 15mm/s, 2mm DOC.
Tool 2) 1/8 45̊ V-bit 5% stepover, 10mm/s 1mm DOC.
I colored it with Kiwi Brown shoe polish and buffed off the excess.
Failures results /solutions:
Windows 10 (Restart), Repetier-Host doesn’t clear cache (Restart), wiring (No Plugs allowed in moving connections).
[attachment file=“Old Man.jpg”]
