Flashing firmware rambo
Hey all I just flashed the newest firmware to my rambo (V1CNC_Rambo_Dual-2.0.7.2-src.zip). It seems successful but on the firmware flashing information page it says “When you see (2) “1 succeeded”, you are DONE and the board is ready to use!! If you do not see that, there are board connection issues.”
But I only see the single "1 succeeded " otherwise the LCD reset and it looks different than the old V1 firmware the board had. Am I missing something? Thanks!
Did you flash using platform.io method ?
Yeah
It is fine. You can confirm the version on the lcd bootscreen, or with M115. It should be 509 or 509D
It does say that! Thanks Jeff!
