I just realized I’m running the same firmware on both my 3d printer and MPCNC that I originally installed probably 2 years ago now.
How often do you update firmwares? I’m running Repetier on a RADDS board on the 3d printer and whatever version of Marlin that was prior to the endstops revision on a Ramps.
They’re both running really well, so I wonder if it’s even worth updating.
Yikes, update the printer for sure. I am using the latest on mine and it all works better. From where you are I believe the LCD is a huge improvement as well as a ton of motion equation tweaks.
That firmware is only on the mpcnc. My 3d printer doesn’t even have a LCD as I control it through octoprint. Last I checked, the radds boards was only supported by repetier.
